high rpm's cut out problem
Old Mar 28, 2007 | 10:34 PM
jaylouky502's Avatar
Default high rpm's cut out problem
94 lt1
the engine will cut all the way out as in power but it will kick right back in and out it will do that back and forth until i let off the gas or drop my rpm's under the power band.also it jerks real bad when that happens.
Any help please.
Old Mar 29, 2007 | 11:26 AM
Razor_Blade's Avatar
I would start by checking the fuel pressure.
Old Mar 29, 2007 | 01:32 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Ditto.
Remember
its Fuel, Air, Spark, Compression, I am leaning toward's fuel and when you do the test, do it under load please.
Old Mar 29, 2007 | 05:05 PM
Zralou's Avatar
Make sure you're not hitting the limiter.
Sara Lou
Old Mar 29, 2007 | 09:59 PM
thx for the help
Old Mar 29, 2007 | 10:40 PM
Irish350's Avatar
mine did that when my opti (just cap/rotor) were going out
