pics of the new set up.
Old Mar 29, 2007 | 11:02 PM
PunishedU's Avatar
Originally Posted by 396D1SS
how do the contons fit? ive been thinking about getting a pair
Sorry, couldnt tell ya, they are sitting on my floor. Install will be later this summer when I have my very first garage to work in.
Old Mar 30, 2007 | 12:02 AM
krayzie7th's Avatar
wow! its sick nice job.What kind of numbers are you expecting?
Old Mar 30, 2007 | 08:06 AM
Ponyhntr's Avatar
Originally Posted by colts95ta
Only if hedman husler stepped 1 3/4 to 1 7/8 are small. I made my own steering shaft so I could still have power steering and modified my air box for them to work.
They just look smaller than that in the pics...
Old Mar 30, 2007 | 08:08 AM
Ponyhntr's Avatar
Just noticed how far out your crank pulley is! Hopefully you don't have crankshaft problems.
Old Mar 30, 2007 | 08:23 AM
LittleRedZ's Avatar
should be ok, all ysi on lt1s are like that nothing you can do about it, my old D1 hung out about that far also
Old Mar 30, 2007 | 08:24 AM
LittleRedZ's Avatar
asp pulleys and I built the bracket for the head unit and modified the some s-trim brackets.I have 3 set ups on these pulleys, another 50mm and a 35 mm cogs if anyones interested. Mine s still not all done yet. Its just money but I have to many hobbies and this is a huge one. lots a money. It getting there though.
I have Sykoras bracket and his old record setting Ysi that has been rebuild.
Whats teh Teeth count on the pulleys you want to sell?
Old Mar 30, 2007 | 04:39 PM
Ponyhntr's Avatar
I hear of guys breaking old-school SBC forged cranks all the time, and they don't hang out that far. Cog-driving a big blower like the YSI is hard on parts, a lot harder than your old D-1, which by the way had a MUCH shorter spacer between the balancer and pulley-less than 2". His is a lot bigger than that.
Old Mar 30, 2007 | 05:07 PM
colts95ta's Avatar
they are not all that hard to turn and if you put two keyways it helps alot. I also have the bbc snout or hub on it which helps alot. Thanks for your thoughts though.
Old Mar 30, 2007 | 05:10 PM
colts95ta's Avatar
Do You have any pics of your set up. just kinda interested to see more options. They are 68 tooth crank and I believe 28 blower. I will double check and let you know.
Old Mar 31, 2007 | 02:47 AM
lt1383's Avatar
Damn sick setup man ! let us know when get some dyno numbers
Old Mar 31, 2007 | 08:06 AM
LittleRedZ's Avatar
unfortenatly i dont have any pics, but if you got to Cz28 theres a guy up there with same set up, and sykora used to have pics on his car domain i'll try to find it. He ran 78 crank and 28/26 blower, you sure the crank isnt 78?
cuz 68/26 sounds like major overspin, chris overspun his blower with 78/28 set up on regular basis.
n/m i found his car domain site http://www.cardomain.com/ride/827450/2
let me know cuz i still need the pulley set up. pm me with a price
Old Apr 2, 2007 | 09:37 AM
  #32
colts95ta's Avatar
78 on the crank side would definately speed up the blower. Smaller blower pulleys and bigger crank pulleys speed up the blower and bigger blower pulleys or smaller crank pulleys slow slow down the blower. I am not sure if the crank pulley could get much bigger without clearence issues. At 6000 rpm(motor) and I think that a ysi is a 4:1 ratio,and the 68 tooth crank pulley and 26 blower, it would be be at 62769rpm which is less that max impeller speed. The 78 tooth would be about 72000 which would be overspun.I will pm you with a price.
Old Apr 2, 2007 | 06:17 PM
  #33
LittleRedZ's Avatar
My balancer/spacer and 12 rib d1 set up was defanatly more then 2" out and yes my first eagle 4340 crank snaped after 400 brake in miles due too too much tension on the belt(know all about it) I got Scat crank now that has about 15 street passes, 10 track passes and 1500 miles of driving-no problem knock on wood. Coged set up dosent need the tension the 12 rib belt requries, Sykora ran his S/C set up for ages without snaping snouts, on stock snout.
Old Apr 2, 2007 | 08:50 PM
  #34
fergymoto's Avatar
That is a sweet setup. I plan to go with a blower one day. Probably a few years away though.
