Electric Power steering pump
Old Mar 31, 2007 | 12:32 AM
transampimp's Avatar
Default Electric Power steering pump
I'm really interested in deleting the A/C. I want to use an Alternator relocation kit to move the alternator down low, and use an electric power steering pump. Then I want to cut the bracket for the alternator to clean up the top of the engine bay. Anyone ever hear of using an electric power steering pump on a car not intended for it? Many foreign cars have electric power steering pumps that I maybe able to use as a donor.
Old Mar 31, 2007 | 01:38 AM
Captainofiron's Avatar
hmm sounds very interesting.
So basically your belt would just be running your alternator and thats it.
Talk about saving power. and since an electric power steering pump wouldnt cause major catastrophe by failing that makes it even more attractive
Old Mar 31, 2007 | 08:36 AM
LittleRedZ's Avatar
really what would those car be? i'm a mechanic myself and have never seen an electric P/S pump in my life, but have read that car makers trying to accomplish it, theres designs but i dont think its in production yet.
Old Mar 31, 2007 | 08:59 AM
the_merv's Avatar
Veteran: Air Force
I wonder if you can use the LS1 Power Steering Pump, since it turns the same way, and the Belt goes on the outside, not the inside..
Old Mar 31, 2007 | 10:54 AM
LTSpeed's Avatar
Almost all new Hondas and Toyotas since late 2005 have electric P/S pumps. (This only means cars that are undergoing full model changes.)
It's the next big bolt-on, IMHO, because it's easy to do. F-bodies could really benefit from them, especially since theirs don't have any form of pressure regulation. My LT1, for example, has little P/S fluid left after a 150+ run of as short as 30 seconds.
Old Mar 31, 2007 | 10:55 AM
whytryz28's Avatar
Off of a Toyota MR2
Old Mar 31, 2007 | 10:57 AM
96capricemgr's Avatar
I know there are cars with electric assist for power steering but do not know wether it is a pump or something else. Think Saturn is using it. Wonder if this is why LittleRedZ said he has never seen an electric pump?
Really if looking to do a major power saving overhaul of the PS system why not look at non-power options.
Everyone wants to dump all sorts of extra load on the electricals thinking they are saving a ton of power but neglecting to consider the alternator is powered by the engine too and that the only way you can save power is by doing less work, at least in a case like this where you are repeatedly changing energy forms which is ineffienct.
whytryz28's Avatar
and heres how you would wire it up to your car...this guy did it on his jeep
Old Mar 31, 2007 | 12:16 PM
I'm not really looking at this swap for a Horsepower increase. I'm more interested in cleaning up the engine bay a bit. I hate looking at that Alternator so high up. I bet that it would make a turbo kit alot easier too.
Old Mar 31, 2007 | 12:44 PM
A-man930's Avatar
Subscribing...
I'd like to see what a manual setup feels like... without skinnys on the front.
Old Mar 31, 2007 | 12:45 PM
solid95z's Avatar
I have been thinking about this for the last few months. I have yet to find an after market company that makes one. I would definately be interested in one though.
Old Mar 31, 2007 | 01:06 PM
Originally Posted by A-man930
Subscribing...
A true manual setup can feel fine, it is not like a hydraulic system with the belt pulled or anything, a lot of cars have used it over the years.
Old Mar 31, 2007 | 02:56 PM
Mighty Whitey's Avatar
I agree, I had an old s-10 that had manual steering on it.. the only time it was noticeable was at a dead stop... moving greater than 1mph and it was as free and easy as a p/s system..
.... you had to be prepared to counter steer REALLY quick when the truck would start going sideways. seeing as the gear-ratio in a manual rack is lower (numerically higher) than a power unit, it would take more turning of the steering wheel to do the same amount of turing at the wheel.
Old Mar 31, 2007 | 04:54 PM
LittleRedZ's Avatar
get a pinto manual rack and get rid of P/S all toghether. You will have more wheel revolutions end to end but it will almost feel like it has P/S
Old Mar 31, 2007 | 06:09 PM
thesoundandthefury's Avatar
http://www.streetperformance.com/rip...p.php?sku=5171
Just try not to have a heart attack when you see the price...
http://www.flamingriver.com/index.cf...rod/prd356.htm
Old Mar 31, 2007 | 08:08 PM
rkinney's Avatar
Chevrolet is already putting electric powersteering in vehicles, and has been for a few years now. The Malibu, Cobalt, and the HHR have an electric motor on the steering column. Don't know if Chevrolet is going to use eps (electric power steering) on larger vehicles though.
Old Mar 31, 2007 | 09:56 PM
A-man930's Avatar
Originally Posted by Mighty Whitey
...seeing as the gear-ratio in a manual rack is lower (numerically higher) than a power unit, it would take more turning of the steering wheel to do the same amount of turing at the wheel.
I don't think this would be apropriate for a handling aplication... even a well-rounded street setup. Are there any manual setups that don't decrease the steering ratio? or at that point does the effort required become too high?
Old Mar 31, 2007 | 10:10 PM
the_merv's Avatar
Veteran: Air Force
Originally Posted by thesoundandthefury
[url]
**** that...
Old Mar 31, 2007 | 10:33 PM
whytryz28's Avatar
LOL just ONLY 3,999 ...i like that alot
Old Apr 3, 2013 | 04:47 PM
HRHohio's Avatar
Bump....
Anyone get any further on this in the past 6 years?
