94 Camaro Z28 Dyno Numbers
Makes me feel alittle better. I had some bad pulls, kept down shifting and would not get above 5000 rpms, and I put down like 237hp and 276 tq. So with some tuning, I should get about where you are. We have similar mods, minus the mid's and Y-pipe.
-bryan
-bryan
i think thats not bad considering all you have is an exhaust setup. 1/4 times are pretty good too conidering its an a4 with 2.73s. stock a4s run really high 13s and even really low 14s so id say you're doing alright. 13.4 is like half a second reduction with just intake and full exhaust. a heads and cam package in your chilling in the 12s.
Originally Posted by 96capricemgr
Should have tried the STOCK programming would have likely matched or maybe even bettered your numbers. The Hypercrap is pretty well documented as crap that slows your car down.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
