Rocker arms adjustment question.
or it should start even if I started installing the rockers following the TDC by starting with the wrong cylinder? I bought a 93 LT1 and I was told it ran great, before I droped it in my Z28 I just installed a 1.6 rockers replacing the stock ones and the engine didn't wanna start and back fire like ****.
I'm just concerened if the engine IS ok and I just did something wrong installing the rockers. What do you guys think?
How do you know if to start with #1 or #6?
Thanks so much man.
How are you adjusting them? Specifically what do you consider zero lash?? I have seen a lot of guys spin the pushrod to find zero and by the time you feel resistance on the well oiled pushrod spinnng in the well oiled cups you are well past zero lash.
