change cam or no?
Old Apr 1, 2007 | 01:12 PM
littlebird's Avatar
Default change cam or no?
I have 160k miles on my motor. it still runs pretty strong, I am wondering if changing the cam without rebuilding the motor (new cam bearings) is a bad idea.
Old Apr 1, 2007 | 01:17 PM
96lt1m6's Avatar
if you drain the coolant and change oil after instal you should not have any real problems.just remember every engine has had a different life,with the mileage you have valvesprings will definately need to be changed.personally i would go for it
Old Apr 1, 2007 | 01:19 PM
carzman5678's Avatar
I would kiss main bearings good bye(I say this from experience). Cam bearings means the motor needs to come out also.
