what length pushrods
Old Apr 1, 2007 | 07:05 PM
chameleongreen97ta's Avatar
Default what length pushrods
I have some stock heads that are ported a little not much but they are still ported. I need some pushrods to finish my 383 and i do not know what length i need. The cam i am using only has .510 lift so it is not that big. So what length should i buy.
Old Apr 1, 2007 | 07:49 PM
Formula WS6's Avatar
IT would be best for you to purchase an adjustable pushrod to figure out the correct length so you achieve the proper geometry.
unless of course someone has your exact set up and knows the awnser
Old Apr 1, 2007 | 10:43 PM
Tony Shepherd's Avatar
7.2 should be close but I would still measure to be certain.
Old Apr 2, 2007 | 12:48 PM
slagger's Avatar
if you need any 7.3 I have some :-)
.080 harden one piece
Old Apr 2, 2007 | 06:57 PM
seawolf06's Avatar
Get a pushrod length checker and see because it's different for every setup.
Also make sure you get high quality pushrods. Don't skimp on those.
Good luck.
