crane hi-6: what do i need?
i decided on a crane hi-6. from what ive read, im going to need a GM HEI harness because i have an OBD-I car. i was also wondering if i should go ahead and get a coil too. has anyone used the lx91 coil? also, am i correct in assuming i dont need a trigger? i hate to bother you guys with this stuff, but i did as much research as possible and am still unsure. i just want to make sure im ordering the right stuff. thanks guys.
If your coil ain't broke, don't fix it. They are all the same.
Using the MSD harness makes install much easier and you can disconnect it very easy if you ever need to troubleshoot.
If you ever want to run nitrous, you might want to look into the Mallory 685 box. I'm not sure how it compares to the HI-6, though.
