Stock '93 LT1 times?
Old Apr 2, 2007 | 09:43 PM
Speedmonster185's Avatar
Default Stock '93 LT1 times?
I'm not sure if this is the right forum for this... If not let me know and I'll delete it and move it to the right one...
Anyway, I'm getting ready to buy a '93 Z28 this weekend for my DD and I'm just wondering what kinds of times those cars run? I didn't think they changed much of anything except some small things, but on the site I'm looking at it says 14.4 for a stock '93 Z28, and it says a '96 Z28 is 14.1, SS is 13.8. From what I heard I was thinking all the Z28 LT1's ran a low 14. The thing that makes the 14.4 kinda hard to believe is that it says the '90 Iroc-Z ran a 14.4. The car is in pretty good shape mechanically. No problems that he knows of. Transmission was rebuilt about 10k ago so that should be good. Bad tires that need replacing.
So whats the story on what the LT1s, including that 93, run?
Old Apr 2, 2007 | 09:45 PM
Speed Density's Avatar
hashtagBMW
www.speeddensity.org
Site dedicated for 93' LT1s
Mine went 14.4 @ 97mph stock.
Tony.
Old Apr 2, 2007 | 09:46 PM
emerica4601's Avatar
From: king of prussia, pa (home) and williamsport, pa (school)
anywhere from 13.9-14.5
depends on the driver
Old Apr 3, 2007 | 10:09 AM
sdm1234's Avatar
and the track.
Old Apr 3, 2007 | 10:25 AM
LT1MAN's Avatar
all ls1 z28's do. it doesn't take much to get there though.
Old Apr 3, 2007 | 10:27 AM
Tony Shepherd's Avatar
Mine went 14.00 bone stock.
Old Apr 3, 2007 | 11:18 AM
street demon2k3's Avatar
14.7@93, yeah I know it sucks. but some LT's, stall, and slicks net me a 13.03@103. dont worry about it too much cuz I never see a "stock" LT1 nowadays, good luck!!!
Old Apr 3, 2007 | 11:38 AM
BizZzatch350's Avatar
Moderator
I ran 9.1@78, 2.25 60ft when mine was all stock, probably would have been a low 14 sec high 13 sec car stock on a good day
Old Apr 3, 2007 | 01:31 PM
Formula350's Avatar
Aside from my sig (Haven't gotten around to the TBody yet) mines basically bone stock :\ I haven't made it to the track though, so I'm not much help, sorry. You'll love the car though.
Old Apr 3, 2007 | 02:31 PM
spyderking69's Avatar
1 went 14.1 stock, but a couple mods and a bottle now she runs 12.7
Old Apr 3, 2007 | 02:33 PM
Puck's Avatar
When I got my 93 with just deleted cat(straight pipe), flowmaster muffler(hardly worth 3hp), and 245 khumo street tires I ran a 13.9. This is in low/no altitude florida though on a fairly chilly track day.
Its around ~14.0 for most good running stock lt1s depending on altitude and weather.
Old Apr 3, 2007 | 03:25 PM
1QWKT/A's Avatar
I ran an 8.67 1/8th mile with only a K&N Intake.
Old Apr 3, 2007 | 06:29 PM
Ok, sounds good. How do these cars hold up at higher mileage? The one I'm getting has about 135k miles. Just had a rebuilt tranny about 10k miles ago though, but how well does stuff hold up? And do they run consistent times into the higher mileage, or does that start dropping too?
Thanks for you help
Old Apr 3, 2007 | 07:42 PM
there was a post a while back on a 200k mile + LT1 that spun a bearing, try a search. But for the most part the LT1 is a pretty stout motor granted you maintain it correctly.
Old Apr 3, 2007 | 09:32 PM
vin1382's Avatar
Thanks for you help
my daily driver 96 lt1 has 154K miles on it. 6sp has not been rebuilt and still shifts fine. engine is still fine, maintains good oil pressure. put 76K miles on it in 2 years. has been rock solid, the only issue i had is when i blew a fan fuse and the car overheated and i had to replace the radiator because it started leakin.
Old Apr 3, 2007 | 10:57 PM
Anyone know why this car might be doing the opposite, not being able to get up to temp? He said thats the only mechanical thing he knows of.
Old Apr 4, 2007 | 04:22 PM
lethal93ta's Avatar
probably just a stuck open thermostat, my car ran a 13.7@102 stock. only thing to watch for on any LT1 is water pump leaking, if the opti wasnt replaced plan to. thats the biggest things to go wrong on the car.
Old Apr 4, 2007 | 04:26 PM
I'm pretty sure he tried replacing the thermostat already... Thats what i was thinking at first too...
What exactly is the opti? (sorry, brand new to LT1's )
Old Apr 4, 2007 | 07:10 PM
vtec's Avatar
Resident Racing Jerk
try a different temp. sending unit. its on the head.
opti is the distributor, located on the front of the engine under the waterpump.
i tore down my 140k mile heads/cam LT1 due to worn rings. (not bad, but too bad to be in my race car)
main/rod bearings looked great with zero copper showing, but the cam bearings had some wear.
Old Apr 11, 2007 | 12:45 PM
erickeown's Avatar
ive seen that sight, i also saw a 93 comparison between the cobra and the camaro where the camaro got a 5.3 0-60, and a 14.0 1/4 mile (m6). Mine went 14.0 stock. 93 Z28 a4
