02 sensor question
Old Apr 4, 2007 | 05:32 PM
ricknbird350's Avatar
Default 02 sensor question
the bank 2 02 sensor is originally after the cat on the stock exhaust right?
if so then when i put my long tubes and true dual exhaust on that sensor should set the check engine because there is no cat there so it thinks its bad right?
when i got the pcm4less tune i told him no cats and the light still comes on.
should i just get the 02 sensor or is it getting a false reading due to no cat?
Old Apr 4, 2007 | 06:20 PM
383_LT1_1295's Avatar
what year is your car?? My bank 2 sensor is on the manifold and bank 1 is on the Y-pipe before the cat. i have a 94 z28.
Old Apr 4, 2007 | 06:35 PM
its a 94 formula, so i guess mine was never after the cat then? so it must be a bad 02
Old Apr 4, 2007 | 08:20 PM
dhdenney's Avatar
How do you know it's throwing a code for an O2? I would scan the car first before I bought a new O2.
Old Apr 5, 2007 | 08:13 PM
because when im crusin down the road the check engine light comes on and i took it to autozone and it said oil temp sensor (doesnt exist?) and optical sensor low resolution (bad opti?) and bank 2 o2 sensor
Old Apr 5, 2007 | 08:30 PM
dhdenney's Avatar
Was the oil temp 58, 59, or 79? Those are trans fluid codes. 16 is a low res failure which is a bad opti. Personally I'd be more worried about the opti than the O2. But about the O2, you're not going to get an O2 DTC because of the no cat I don't think. Either way, the oxygen in the exhaust at the O2 is going to be the same whether you have a cat or not so I would say the sensor is bad.
Old Apr 6, 2007 | 01:19 PM
ok thanks. i knew the opti is on its way out. it takes awhile to start. it will start and stall. i dont have the money for a new opti tho
Old Apr 6, 2007 | 09:31 PM
dhdenney's Avatar
You won't have choice when you are sitting on the side of the road, lol. That's what happened to me.
 Michael S. Palmer
