I need some help!!!!
Old Apr 6, 2007 | 03:16 PM
Mike96z's Avatar
Default I need some help!!!!
Alright, my crank hub spun of my crank, took the bolt out with it. It screwed up the threads inside the crank. I got a new bolt, new crank hub that takes a crank key. If anyone can do this or know a place that can do it today! I need the threads in the crank fixed while the engine is still in the car. I cant get the screw to go in there. I either need the threads fixed or a helacoil (however you spell it). 972-679-5322 Need this done today! Im in texas!
Old Apr 6, 2007 | 03:30 PM
LTBANDIT's Avatar
wow, honestly, good luck...
you can try to chase the threads with a tap and see if that works... otherwise you may need a new crank...
i had a similar problem... (my hub didn't fall off) i screwed the threads up when i pulled the hub... i was lucky enough to have some good threads at the bottom...
best of luck to ya...
Old Apr 6, 2007 | 04:40 PM
daniel6718's Avatar
you can try something with a more course thread since they are ""taller"" and just run it in there...the hub should fit so tight you dont need a bolt...only the balancer(i wouldent reccomend this...
Old Apr 6, 2007 | 07:46 PM
lifeisgood's Avatar
you do not repeat do not need a new crank.lol
if worse comes to worse drill the old hole a 1/16 bigger and tape for that drill bit. you can fix this. i had this problem on a buddy's car.
Old Apr 6, 2007 | 08:59 PM
LTBANDIT's Avatar
if u screw it up enough u will... and your not going to go from a 7/16" bolt to a 1/2" bolt... i thought about doing this and the 1/2" bolt will not fit thru the hub...(you would have to drill out the hub also...)
unless you yourself did this then i will put my foot in my mouth...
anyway good luck...
