th350 lt1
Old Apr 11, 2007 | 05:43 PM
prairieArrowLT1's Avatar
Default th350 lt1
what will the rpm's at 60mph be with a th350 and 3.42's, with stock size tires?
Also what is all neede for a th350 conversion?, a different driveshaft? transmission brace....I have a t56, just put a new clutch in, and I think something is wrong within the trans, so im thinking of taking it out
Old Apr 11, 2007 | 07:19 PM
LT1Falcon's Avatar
ide say youd be at about 2700 rpms, maybe a little higher since no lockup
Old Apr 11, 2007 | 09:49 PM
smoknta's Avatar
If you get the correct length tailshaft, you can use the same length driveshaft.
The correct way to do it would be to get a switch kit from Tekpak Fitzall. This kit comes with an output shaft, and spacer. This allows you to run the tailshaft off of your exsisting tranny and use the same speddo sensor. That way you can use the same crossmember, same driveshaft, and the same speddo sensor.
This is the route I'm going.
Old Apr 11, 2007 | 11:43 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
if you want to know what it would be like to have it in your car...just drive it around in third gear...both trannys (th350 and 4l60E) have a 1:1 third gear
Old Apr 12, 2007 | 06:13 AM
LT1Falcon's Avatar
yes thats true, thats how i came up with the 2700 number, but he said he has any m6 so should he use 5th gear? or is 4th 1:1
Old Apr 12, 2007 | 10:13 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
sorry missed the fact he was a T56...yes 4th gear is 1:1
Old Apr 12, 2007 | 12:44 PM
LT1Falcon's Avatar
so use fourth gear and dont forget that the converter is gonna slip a little, especially higher stalls. there are some websites that allow you to punch in you configurations (tire size, gear ratio, etc) anf figure it out, but still remember the converter
