Update on the swap..
Old Apr 15, 2007 | 04:20 PM
  #41
the_merv's Avatar
Veteran: Air Force
It's just newer Technology, that's the way it happens, so might as well jump into it with a good setup while representin the older looking car, and suprise the hell out of people..
Old Apr 15, 2007 | 04:53 PM
  #42
1bdbrd's Avatar
ive been wanting an LS1 fbody for the past 7 years and started collecting parts to swap my 94. i might still do it later this year depending on total costs.
Old Apr 28, 2007 | 09:12 PM
  #43
the_merv's Avatar
Veteran: Air Force
With the LS1, you are probably looking at $5k tops. That is doing everything yourself. I am estimating about $6-$7K for my conversion. Right now it's a hair under $6k with everything I have gotten so far, but I always leave a little room to play.
UPDATE: I got in a Yank SS3600 Stall to go in it, it's a 9" Convertor, really light weight. The Block and Heads went to the Machine Shop, Block is getting all cleaned up, and the Heads are getting Milled .025. The Compression after it's done will be about 10.7:1.
Soon I will be dropping the LT1 out of my car and shipping it to the guy that bought it, then I am buying the Crank/Rods, then the Pistons/Rings. Then I got to get them all Balanced, after that it's the Cam and Springs, get the Heads assembled, then it's getting all the little crap all together.
Old Apr 29, 2007 | 12:25 AM
  #44
plaf713's Avatar
what trans will you run?
Old Apr 29, 2007 | 01:19 AM
  #45
the_merv's Avatar
Veteran: Air Force
Built LS1 4L60E, a guy I know here builds them to handle about 700+hp in Trucks, so my light Car isn't going to have a problem with it.
I got the Tranny for $165..
Old Apr 29, 2007 | 10:06 AM
  #46
Matts94Z28's Avatar
Im definatly going to watch this thread. Im going to be parting out my LT1 over the winter and im going to do a similar build except i might go single plane. Its nice working for GM and getting certain things for a core charge
Old Apr 29, 2007 | 10:15 AM
  #47
94CamaroZ28SS's Avatar
is that the tranny you were going to sell to me? the motor looks awesome.
Old Apr 29, 2007 | 12:07 PM
  #48
the_merv's Avatar
Veteran: Air Force
No, I have the built LT1 4L60E for sale.. it's coming out of the car this week. Only got 1200 miles on it..
Trust me, I'll definately keep posts on this if people are interested, it's going to be a killer setup. So far I have everything documented, notes on the Harness that I built, all the little stuff..
Old Apr 29, 2007 | 12:31 PM
  #49
Matts94Z28's Avatar
Sounds good, cant wait to see what it runs! So you do you plan on making anymore of the harnesses? If so i might be interested at the beggining of the year.
Old Apr 29, 2007 | 12:38 PM
  #50
SocalZ's Avatar
What difference would it make if you had the heads ported, 30 cfm? They flow around around 330 untouched correct. Doesn't the l76 become a restriction at that point?
I've seen these builds put down some serious power.Time to get a 12 bolt. As much as I love my Lt1 I wouldn't mind having this combo. Keep us posted.
Old Apr 29, 2007 | 01:08 PM
  #51
the_merv's Avatar
Veteran: Air Force
I can start making Harnesses for a little bit of mod money..
I am just leaving it where it is, the bottom end and Cam will be perfect for it.
They are GM Factory Parts, and they beat 95% of the aftermarket..
Old Apr 29, 2007 | 07:06 PM
  #52
the_merv's Avatar
Veteran: Air Force
Also, the Power Steering has to be switched out for a LS1 Rack. The Linkage connection on this Rack is at a greater angle, and clears the Headers better, pushes it closer to the Wheel Well. Also, the Linkage looks a hell of alot better..
Here is some other pics.. I have been playin with my parts..
This is the Harness I custom built. You might notice the LS2 Injector Connectors, the rest probably looks normal..
This is what you will see when I pop the Hood..
Old Apr 30, 2007 | 10:37 AM
  #53
daniel6718's Avatar
merv, wat did you pay for your rack and where did you get it? pm me
