Is an electric water pump worth it?
If you truly run your car at high rpm only (or mostly) I find it difficult to believe that you drive on the street. Even my motorcycles run mostly lower rpms unless I can find an empty stretch of road where I can open them up.
If you drive on the street, your rpm are mostly lower (IMHO), and the maximum flow rate of a mechanical pump must be discounted. Our LT1s are supposed to shift at 5700, IIRC.
If you change a part for a different one, and gain horsepower, then the new part must be more efficent than the old one. How could it be otherwise?
Efficient would imply doing the same work but using less energy. The electric pumps do less work using less energy.
Far as the discounting the mechanicals max flow as I said when you need more cooling is under load and I don't know about your car but if mine is under load the rpms are probably climbing in a BIG way. If you want to talk low rpm though how about 20gpm at 2000rpm that is probably in the ballpark for everyone's cruise rpm right?
I have no way to test it but I bet the electrics restricted by the cooling system do not actually move much more than that, Alan's car running warmer at cruise backs this up.
The LT1 might be factory set to shift at 5700 but most bolton cars will shift higher than that even the b-bodies with their "truck" cams shift around there with a good tune.
--Alan
+1 FTW
