Is an electric water pump worth it?
It is pretty foolish to believe a "new" stock pump is better than a reman. I mean you honestly think GM is going to bother still making pumps for an engine that has been out of production a DECADE? Whick means you are buying something that has been sitting on a shelf forever which explains why a lot of guys have them leak immediately upon installation.
Electrics can provide a little dyno and strip gain BUT do so by moving LESS water. MOST of what you will find people using as supporting reasons are a pile of bull. I am not saying they are bad. They do the job just that there is a lot of missinformation about them.
2500 hours is a loooong time. I used quality components when I installed my pump and I expect that it will be trouble free for another 3 years when I'm plan to replace it.
I know that some people don't trust electric water pumps; I remember the same type of naysaying when mechanical cooling fans were being replaced by electrics. I wonder if the same naysaying went on when electric fuel pumps replaced the mechanical ones.
As for worth it, if you want another 5-10 hp it's a good bang for the buck mod. If you are on a tight budget and the car is stock use a rebuilt mechanical pump. People spend more money on speed parts that end up providing less of a gain.
Mike
Far as the reliability, I know they last a good bit of time and I know mechanical or electric they will eventually fail. The reason I like the mechanical is the slow weeping failure that give you notice and always continues to pump water unlike the sudden total failure of the electric. That combined with the relatively good availability of mechanicals is why I recommend them on the street.
The wet opti concerns are GROSSLY overblown. The opti is a distributor as such if it gets wet inside it will act up, once it dries they also start working again. I wonder how many fools have bought new optis just because theirs was wet and acting up
and the internet told them how bad it was.
I used to be into offroad trucks and have drowned out HEI distributors that were 4 feet off the ground, give them some time to dry or open them and dry them and go on your way.
when you drain coolant you dont ahve to risk overheating it while refilling with water...just turn the key on and it will pump the water out....kinda eliminates the problems with lt1's(air stuck in the motor) and the one that i dont understand (water on the opti)
Mike
How simple are you people, open the garage door when you run the car
.Do you understand the alternator is driven by the engine? The electrics free up power by moving LESS water than the mechanical does at higher rpms, I have beaten this to death but there are a lot of stupid people out there to try to educate.
axeman there is no high flow mechanical though I have seen stockers advertized as such.
Last pump I bought was a Cardone Reman from Advanced Auto online store for $42.
You are buying into marketting BS.
Serving up a steaming pile of bull is the prefered sales tactic over tuely good products and most people are not able to sort out the two which is why there is crap like Hypertech and Granatelli.
