th400
Old Apr 14, 2007 | 09:22 PM
97Lt1TA's Avatar
Default th400
will a 97 m6 wire harness work with it? also im aware i will need a crossmember but what driveshafty will i have to use with it? thanks
Old Apr 15, 2007 | 11:11 AM
dhdenney's Avatar
I believe the easiest way is to install the A4 reluctor and sensor in the TH400 housing. But then you would have to have your PCM modded for a the 40X reluctor opposed to the ?16X M6 reluctor. You can splice in the A4 pigtail in place of the M6 pigtail to avoid getting a new harness. I think driveshaft will have to be a custom job.
