stock advance?
No I flashed my cars pcm with magic fairy dust. I have no data logging capabilities at all
I'm aware that pinging is different than knock, and if you did add 5 degrees everywhere with no knock, good for you. All I'm saying is that just because that worked for you does no mean everyone else will be able to do that. From the LT1's I've worked on, it's clear to me that most with moderate to high mileage will not be able to do that without seeing knock. It might just be the case that you have an exceptionally strong running car.
In the GM shop manual the test it says to perform to determine if the sensor is bad involves measuring the resistance from the sensor to ground. If the resistance is outside the expected range, then the sensor is bad. However if that is the case, the voltage the pcm sees from the sensor will also be outside the expected range because the voltage drop across the sensor circuit will be affected in a nonstandard way by the nonstandard resistance of the sensor.
I'll give you that I suppose its possible for the sensor to fail in some way that would still provide the expected voltage, but that would be an unlikely event IMO. In most cases, if the sensor is dead, i.e. not working, the pcm will know about it and set the knock sensor code.
Fyi, here are the values:
for obd1: the resistance should be 3300-4500 ohms
for obd2: should be 93k-107k ohms
