I need a new Torque Arm..
UMI makes a good product i got there adj panhard on my car.. but i got one of there torque arms and it doesnt fit they told me to try the other holes that dont fit either $200 piece of junk atm
![](http://i12.photobucket.com/albums/a243/Gun5/DSC00705.jpg)
crossmember whats that ****, took that bitch off wieght reduction if anyone believes GM's theory that a torque arm can break and make the car turn end over end be my guest
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
Originally Posted by Paul Bell
Go with the UMI arm and crossmember with the safety loop. The crossmember with the exhaust clearing drop hoop may hit everything on the road like mine did. I swapped it to a flat one and still have a huge exhaust passing over it.
UMIUMIUMI...
UMIUMIUMI...
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#34
Originally Posted by the_merv
I was messing around and went to back up, it wheel hopped a bit, so I stopped and started to take off. I had a friend with me so we were having a little fun, I hammered it and it went snap and I heard a little grinding, so I thought I dropped the Gears again..![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I got under there and I saw this..
![](http://i103.photobucket.com/albums/m129/the_merv/BROKENTORQUEARM.jpg)
The Drive Shaft was rubbing on the Exhaust, and it's missing a Bolt, it's in the road somewhere..
Time for an adjustable Torque Arm..![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#37
It that picture you are trying to use the WRONG holes, slide the arm to the right and use the other holes. If that arm slide on that far to almost use the inner holes then that means it slide WAY past the other holes to get that far, correct?
Everytime I reply your e-mails it takes you 2-3 weeks to reply back.. I just gave up.
Ryan
Ryan
#38
So while talking about cross members, anyone fitting 3" exhaust over a spohn one that isn't the one thats dipped down? I keep scraping my spohn crossmember off of everything, and I want to lower my car which I can't possible think of doing while running the cross member with the dip in it.
#39
Im about to install my kooks long tube with the matching "y" pipe and wanted to know if a straight cross member would be ok in terms of clearance.
