JUST IN LE2 Dyno #'s....
Only weight reduction if you can even call it that is !swaybar, !spare/jack, and prostars (mickey t dr's aint't light though)
Last time I weighed it was *before* the Ford 9", I'm not sure what the exact difference is between the 10 bolt and the 9" is.
Anyways, it used to be 3330lbs w/o driver..
With me in it, it tips the scales at 3500lbs plus the weight difference of the the Ford 9"
Thats very encouraging. Hardtop? I have took alot of weight out of mine but its a t-top car. Running the LE2 with a fresh shortblock thru an M6 and 10 bolt. Taking out quite a bit of weight though.
My goal is to have a fully streetable w/ air conditioning 10 second n/a LT1 car.
After what I've seen through my big stall automatic and a Ford 9", there's no reason an M6 LE2 or 3 car shouldn't be solid into the 120's. None at all.
Thats what I'm hoping! I don't expect more than high 11s with the 10 bolt and the M6. But 118-120 traps are my goal
BTW who did the tuning?
Just gotta find where the rest of the power is hiding.
Who knows I may just find a stock LS1 and trade straight up!?
It should be that easy......
I dont see why it would be a hard thing to do...
Theres a member on here that is making 420whp with a decent sized cam with stock unported heads and a good tune
