Which o2 sim?
Old Jun 10, 2007 | 10:21 PM
A-man930's Avatar
Originally Posted by Ralls
I'm not 100% positive if the REAR o2's use a flat connector (type 5) or a square one. I know the fronts are. I'm '94 so I never seen myself. Someone 96-97 needs to chime in.
Well, I know that the one I replaced (on the wrong side ) was the square type... I just don't know which one, typed 1-4 are all square. I guess the question I should really be asking is where the rear O2 on the left side actually is I have had absolutely no time to get under my car!
Old Jun 11, 2007 | 12:31 PM
Ralls's Avatar
Shouldn't be hard to spot. It will be after your cat on the left side. So just jack it up and stick your head under the engine side. I would suggest taking it out and look at that diagram to see what type it is. It should be type 1,3, or 5
Old Jun 11, 2007 | 02:10 PM
SlowGreenTA's Avatar
On my '97 the rear O2s are square type, the fronts are flat type connectors.
