Which o2 sim?
Old Apr 19, 2007 | 03:01 AM
Bowtie Boy's Avatar
Default Which o2 sim?
I will be eventually putting headers on my 97 and dont want the cats...dont wanna get a tune right away so gonna use o2 sims...
http://www.afterthoughtsauto.com/o2sim.html
There is a chart on the bottom of that page, does anyone know what type of connector I need to get?
Old Apr 19, 2007 | 01:00 PM
Bowtie Boy's Avatar
Here ill make it easier...
Old Jun 2, 2007 | 08:19 PM
A-man930's Avatar
Ditto... I need to order one pronto, before I'm out of town.
Old Jun 2, 2007 | 08:24 PM
Ralls's Avatar
Type 5
Old Jun 2, 2007 | 09:27 PM
A-man930's Avatar
What about the post-catalyst?
Old Jun 2, 2007 | 11:14 PM
A-man930's Avatar
Bump... need to order one tonight!
Old Jun 2, 2007 | 11:37 PM
Formula350's Avatar
Well, crawl under your car, duh.
Old Jun 2, 2007 | 11:51 PM
Rowdy94's Avatar
Look and seeeeee! I'm just going to use the kit that comes with my PaceSetters. A little solder here and some shrink wrap there and you're done. I'm cheap
Old Jun 3, 2007 | 12:41 AM
speed_demon24's Avatar
Don't waste teh $$ on 02 sims, just get a tune. You won't pick up much power with headers alone since they will throw your tune pretty far off.
Old Jun 3, 2007 | 01:51 AM
Rowdy94's Avatar
I wasn't thinking straight...it's late and I've had a few. I was referring to the extensions above. For sims, I say screw it. I can tune them out right away, but if you can't, just deal with the SES light until you can get a tune.
Old Jun 3, 2007 | 03:49 PM
Formula350's Avatar
It won't run right if the SES is on.
Old Jun 3, 2007 | 03:56 PM
Ralls's Avatar
Not true
Old Jun 3, 2007 | 04:00 PM
landstuhltaylor's Avatar
the only significant change because of the ses light is your fans will always be running
Old Jun 4, 2007 | 12:17 AM
A-man930's Avatar
Ok, it's kinda hard to crawl under the car when it's not at my house, otherwise I already would have done so... lol. The only reason I'm bothering getting a sim is to pass the state emissions scan and get rid of the SES. When I get a tune I'm doing it with an OBD1 swap and that won't pass the scan either... One ecu to pass, one to actually use
Old Jun 4, 2007 | 04:28 AM
Formula350's Avatar
Originally Posted by Ralls
Not true
So unplugging your O2's is no problem? Running your car w/o them won't cause a single thing to perform different other than the fans being on? So why are we running them? I might as well not bother trying to change my Pass side and just unplug it. Save myself $18 on the O2, go have a few beers!
What other sensors don't I need that I can unplug?
Old Jun 4, 2007 | 05:54 AM
Ralls's Avatar
Aren't we talking about rear o2's? All they do is see if the cat is working. It has no control over A/F ratio.
Old Jun 4, 2007 | 01:33 PM
Ralls's Avatar
I'm not 100% positive if the REAR o2's use a flat connector (type 5) or a square one. I know the fronts are. I'm '94 so I never seen myself. Someone 96-97 needs to chime in.
Old Jun 4, 2007 | 03:29 PM
Formula350's Avatar
I can't see the point in having a rear sensor if all it does is make sure the cat is fine. That's like having someone sit and watch a huge boulder to make sure it doesn't move. Sure, eventually it's going to move, but not for a few thousand years heh So you're just going to be replacing the people watching it every time they die, for something that you know won't happen for eons.
Old Jun 9, 2007 | 08:35 PM
because when cats go bad you want to know. your car will perform like absolute **** if it gets clogged, that and it wont satisfy emissions testings.
Old Jun 9, 2007 | 10:43 PM
Albosky's Avatar
Tell that to the Federal folks who write the emissions laws. GM didn't put them there because they wanted to.
