O2 Removal
Old Apr 22, 2007 | 07:18 PM
ddasilva99's Avatar
Default O2 Removal
Hi Everyone,
My check engine light recently threw the code:
code P0140 - DTC P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2
Ive been told on another board that I need to replace my O2 sensor. Could someone please provide me with the steps to removing the o2 sensor?
Also, will the following sensor removal tool work on our cars or it is too big/small?
http://canadiantire.ca/browse/produc...r_id=140847439 6672445&bmUID=1177287089418&PRODUCT%3C%3Eprd_id=84 5524443283234&assortment=primary&fromSearch=true
Thank you,
Derek
Old Apr 22, 2007 | 07:25 PM
the_merv's Avatar
Veteran: Air Force
Locate Sensor, remove and replace.
Get you a Crescent Wrench and have at it, it's easy..I think it's either a 3/4 or a 7/8 Wrench for the regular size.
Old Apr 22, 2007 | 07:39 PM
great421's Avatar
Sensor 2 would be post cat; here are the two steps:
Disconnect the 4 pin electrical connector
If you need to, remove the exhaust pipe that includes the failed O2 sensor
Attach a O2 sensor socket then remove the sensor (if you get a good one, it'll have a hex shaped end and you can use a wrench if the ratchet doesn't have clearance)
Installation = reverse.
Originally Posted by ddasilva99
Hi Everyone,
Thank you,
Derek
Old Apr 22, 2007 | 07:46 PM
ddasilva99's Avatar
Thank you for your post. Should I use anything like WD40 to loosen the sensor and some type of compound when installing the new sensor?
cheers,
d
Old Apr 22, 2007 | 08:05 PM
LT1Falcon's Avatar
i found a torch helpful when removing mine. just heat the bung but try not to heat the o2 as much as possible, because it decreases the effect of heating and expanding. you might be able to loosen it up with just a wrench tho, it just varies
