LT1 Swap
Corrrect! I picked up a LT1,transmission,wiring harness and everything else i could find in the engine bay from a recked 94z for $1500 at a local junkyard
best way to do the swap is get the same year so that you wont have problems plugging the dash harness with the engine harness.
for example, the (OBD II) LT1 engine harness wont work with (OBD I) dash harness.
you'll need fuelpump
fuel lines
raiator
engine bay wiring harness
motor
trans
rear end if you want a posi
A/C lines
Front springs/shocks
swaybars front and rear
exhaust
clutch
driveshaft
slave cylinder
manual trans peddles
engine K member
trans k member
I may be forgetting a couple things, but thats a fairly complete list
