LT1 gearing?
Old Apr 25, 2007 | 03:50 AM
Camaro94SS's Avatar
Default LT1 gearing?
So i looked on my door to find the "GU2" or "GU5" code....and cant seem to find it....Then i checked glove box and the sticker is there....but about 90% of it is gone and a little piece of it is there with a few codes.....is there anyway i can obtain a new sticker or figure out my gearing?
Old Apr 25, 2007 | 05:36 AM
Formula350's Avatar
"Pull the diff cover and count the gears" method, or take your vin to the dealer. I think they can still print off your RPO sheet.
Or just put in 3.43 and KNOW what's in there
Old Apr 25, 2007 | 05:41 AM
LT1Falcon's Avatar
its pretty easy to figure your gearing out, especially with 2 people and positraction. one person gets under the car and rotates the driveshaft, and the other person sits beside the back wheel and counts how many times it goes around. if it takes 3 and 23/100 driveshaft turns to rotate the wheel once, you have 3.23's. if it takes 2 and 73/100 times you have a 2.73 and so on and so one. not perfectly accurate but good enough and a lot easier than pulling the cover
Old Apr 25, 2007 | 06:33 AM
koolaid_kid's Avatar
Not sure if this is true on the 94, but there are a couple of ways to tell on the 97:
Do you have first gear available on your console? If so, it has a 3.23.
Is your car speed limited to 110 mph? If so, it has a 2.73.
Do you have Z-rated tires? If so, it has a 3.23. This may not work for you, since the tires have most likely been changed.
Old Apr 25, 2007 | 10:39 AM
01WS6/tamu's Avatar
You do not even have to do all of that crap pull the cover off and locate the numbers on the ring gear. You will find two numbers with a colon between them divide it and that will give you your gear ration. Or grab the vin call a dealer and they can tell you.
Old Apr 25, 2007 | 11:41 AM
Camaro94SS's Avatar
I think im gonna take it to the dealer...but yes i have 1st gear available in the console....i think i have 2.73s because my car ran a 14.0 bone stock with only CAI and i was looking through the dyno thread and noticed a 95 trans am a4 with 2.73s that ran 14.0 stock completely.....my car also doesnt have rev limiter and no top speed limiter....im hopinbg its 2.73s so i can put 3.73s and see my ET drop like hell
Old Apr 25, 2007 | 01:07 PM
LS1Silverado05's Avatar
I went from 2.73s to 4.10s. Lets just say, you will notice a difference if you are starting with 2.73s. Sounds like you are on track.
Old Apr 25, 2007 | 01:31 PM
Ralls's Avatar
No you don't have 2.73's. Pretty sure you have 3.23's. Just cause you ran a 14sec CAI only, doesn't mean you have 2.73s. They don't kill you that bad. I ran a 13.7 CAI only with 2.73s. Every car is different. You will still feel a big difference from 3.23s to 3.73s. Some people GAIN ET when getting smaller (numerically larger) gears, but that's only because they loose traction.
Old Apr 25, 2007 | 04:04 PM
LT1Falcon's Avatar
im tellin you its easier the way i explained than having to pull the cover, drain the oil, look for the number, put the cover back on and fill it back up with oil, but thats my opinion. i garuntee it takes less time
Old Apr 25, 2007 | 06:04 PM
01WS6/tamu's Avatar
Phone call is quicker than all of the above. But by calculating the numbers on the pinion you know it's dead nuts on. I've never tried the other way so it works however you choose to do it.
Old Apr 25, 2007 | 06:06 PM
slick1851's Avatar
Who cares if your getting a 3.73 anyways, its still going to be a huge gain
Old Apr 25, 2007 | 06:11 PM
LT1Falcon's Avatar
no offense but that was a pretty dumb statement. thats like comparing apples to oranges. what was the weather like for both of you? how many miles do each of you have on your car? who can drive better? what kind of tires did you each have? there are so many variables, you can hardly make a comparison
Old Apr 25, 2007 | 08:32 PM
TravisMcGill2000's Avatar
slick 1851 u got to know wat gear is in your car factor or u cant buy a gear for it. if u have a 2.73 u have a 2 series carrier, and if u have a 3.23 u have a 3 series carrier then means the ring gears are not the same thickness u have to order the right gear or will not work . i know first hand lol
Old Apr 25, 2007 | 09:55 PM
slick1851's Avatar
F it get a 9inch with a 4.56 gear lol
Old Apr 26, 2007 | 12:01 PM
leadfoot4's Avatar
Not necessarily all true, at least not in '96. I have a '96 Z-28. I'm the original owner, and special ordered the car. It has the "Z" rated tires, so it's not limited to 110 MPH; does not have first gear on the selector; and does not have the 3:23 gear. Because it's my DD, and I didn't need the extra RPM while cruising back and forth to work on the interstate, I opted to stay with the 2:73s. Secondly, the 3:23s were a $250 option.
Old Apr 26, 2007 | 01:47 PM
Camaro94SS's Avatar
none taken, but it was street tires, both were automatics...as far as weather obviously hav eno clue, but you can still make somewhat of a comparison...but i do see your point....i guess i consider myself a decent driver cuting 2.0 and 1.9 60s on fairly decent street tires....then again i could be garbage lol
Old Apr 26, 2007 | 06:07 PM
GMRL's Avatar
Heres the easiest way, assuming you have stock sized tires and wheels.
Take it for a drive, get it up to 60 MPH.
If your sitting right around 1800 RPM in overdrive, you have 3.23s
If your sitting right around 1500 RPM in overdrive, you have 2.73s.
Old Apr 26, 2007 | 09:42 PM
cody161's Avatar
dude you are an auto 2.0 are easy lol
Old Apr 26, 2007 | 10:09 PM
I agree, special order cars can vary. Since some extremely high percentage of cars are bought straight off the lot, special order cars must be excluded. However, you also make my point. Your car came with Z rated tires so the speed limiter is higher than 110. You do not have 1st gear selectable, so you have 2.73s (in 97, and apparently 96). For cars purchased off the lot, the two came together in a package AFAIK.
I subsequently looked up the 94 owners manual, and first is always selectable, so it is not true for his car. Just an observation.
