Fuel req
Old Apr 25, 2007 | 02:26 PM
Ari G's Avatar
Default Fuel req
I´m having problems with my fuel supply
I´m in 400rwhp range and installed a 255l walbro but it still sputtering at high rpms,i´m going to buy the hotwirekit but how much hp can the stock fuel lines and FPR support?
I have a new dristribuitor and compleate ignition system so it´s not the cause of the sputtering
Old Apr 25, 2007 | 03:08 PM
Formula350's Avatar
36# injectors, I'd assume you'd be fine. Stock lines I'd only worry about with over 800hp, but I'm just guessing.
Check your fuel filter?
Old Apr 25, 2007 | 03:09 PM
Ari G's Avatar
yes 36# inj and new filter
Old Apr 25, 2007 | 03:10 PM
Formula350's Avatar
I know, I was reading your sig Best I can offer would be trying 50psi.
Old Apr 25, 2007 | 06:27 PM
96capricemgr's Avatar
You are not tapping out the lines or regulator. The hotwire kit is something you should have done already with the pump but I suspect the problem will continue after you get that done.
Old Apr 25, 2007 | 06:48 PM
Ari G's Avatar
not nearly everyone have the hotwire kit and are running fine,so it depends on each application
I´m suspecting the FPR is not holding pressure,getting a gauge to measure it
