Dyno Numbers CC306 Boltons
Old Apr 26, 2007 | 11:07 AM
Formula934's Avatar
Default Dyno Numbers CC306 Boltons
Here is a dyno chart with CC306, Full Bolts Ons, Stock heads, Walbro 255 pump, Stock injectors, PCM4LESS tune, and other items listed in sig. The first three runs were with the cut-out closed. Those were the runs I ran the lowest. The last run I ran with the cut-out open and ran 353RWHP SAE. The odd part about this is with the cut out closed I was leaning out over 18 A/F to the point were we shut down before 6 grand at times. What i dont understand is why the A/F somewhat stablized on the last run with the cut out open but was still around 15. The car is definately running out of fuel which im not sure is due to the injectors or maybe the tune. I know there is alot more power to be made but if anyone has any comments or insight it would be greatly appreciated.
Old Apr 26, 2007 | 11:49 AM
flame's Avatar
First thing to check is fuel pressure underload. If it drops off your pump is junk. The torque is pretty low also my 306 cam only was 346rwhp/338rwtq and the tune wasn't great above 5k rpm. Get your fuel issue fixed and get back to the dyno to make sure things are good.
Old Apr 26, 2007 | 12:02 PM
dhdenney's Avatar
Might also look at stock injectors as a bottleneck. Do you have any way to monitor duty cycles?
Old Apr 26, 2007 | 12:22 PM
street demon2k3's Avatar
I dyno'd 347hp/324tq(stalled A4) with some problems about 1-2 months ago and my inj duty cycles were at 100% by about 4800RPM. might want to check that out just to be on the safe side, cuz its too lean. Unless there was an error with the a/f monitor, I had one read falsely one time so IDK. good #'s BTW, should get some more power once you get those little things sorted out.
Old Apr 26, 2007 | 12:58 PM
moehorsepower's Avatar
Definetly too Lean on the top end, also looks like detonation either due to the A/F or too much timing or both. Check out the duty cycle of your injectors and that will tell you if you need larger ones..
Old Apr 26, 2007 | 01:09 PM
TWS's Avatar
TWS
Exactly.
PLUS: Hook up a Fuel Pressure gauge to your shrader valve. Place it securely on top of the manifold where it can't hit on anything and watch it during the dyno pull. If your pressure falls off steeply at high RPM, then you also need to step up the fuel pump.
Old Apr 26, 2007 | 01:32 PM
Formula934's Avatar
I should have mentioned that the fuel pump was put in less than a week ago and i fully tested with a fuel pressure gauge. It ran 43 PSI and did not drop off under load. However, i think ur right i should have checked it on the dyno.
Old Apr 26, 2007 | 02:08 PM
lt197formula's Avatar
Get some 30lb injectors but that won't fix everything I bet. Your graph looks exactly like mine when I was fighting ignition issues. Ended up replaced the coil, wires, and got a Walbro 255, Msd 6al and Dynaspark. I waited until last to replace the opti hoping it wasn't it but, as soon as the Dynaspark went it, perfectly smooth graph. Let us know how it goes.
Old Apr 26, 2007 | 02:53 PM
Formula934's Avatar
Once again i forgot to mention I just replaced the opti but i guess i cant rule that out just yet either
Old Apr 26, 2007 | 03:16 PM
rasputin's Avatar
353rwhp, still thats pretty damn good!
Old Apr 26, 2007 | 03:25 PM
How about the coil?
Old Apr 26, 2007 | 08:17 PM
Formula934's Avatar
yea it still has the stock coil thats another possibility. What about the fact that the A/F shot down and smoothed out when i opened the cut-out and added 16 rwhp. Anyone have any ideas how that could be, this i why i was leaning towards it being the tune. I know its def running lean but then with the cut out open its actually getting more fuel and making more power. Anyone?
Old Apr 26, 2007 | 08:51 PM
Not sure, hopefully someone who has an idea will chime in. But I would probably replace that stock coil, how many miles are on it? Are you able to get a dyno tune or are there not any good shops near you?
Old Apr 27, 2007 | 05:11 AM
Formula934's Avatar
Its got 99,000 on it so im gonna go ahead and replace it, its a cheap upgrade anyways. As for the dynotune, luckily i got one right up the street from me and the guy quoted me around 500 bucks. Just a little short on money at the moment but ill let you know how i make out once i finally get it tuned. Thanks alot guys for all your help.
Old Apr 27, 2007 | 04:07 PM
Yeah I would replace it and then let us know how things go once you get a dyno tune.
