Can you change the cam without pulling the intake?
Can you change the cam without pulling the intake? I heard that when you pull the pushrods out you can rotate the motor one revolution and the lifter retainers would keep the lifters from falling. Allowing you to change the cam and possible save some down time.
Anyone done it this way?
no, you have to take out the oil pump drive, if you had a gen 3 small block you can do it with the intake on, also the roller cam engines with a standard dist can do it with the intake on
