cut out vs true duals...
No I am not going to do true duals...I was just wondering the diff between the two
I run Purple Horny header mufflers. I took em to an exhaust shop and had O2 bungs welded in and had them shortened a bit to fit my KBDD subframes.
Total.......100 bucks. 40 each for the mufflers and 20 for the welding.
They sound great if you like glasspacks and are easily removed to work on the car.
Some time in the future I plan on doing lobaks with Dr gas boom tubes out the side just in front of the rear tire.
Should be unique.
.................................................. ............NOT!!!!!!!!!!!!!!!!!!!!!
It is not enough to notice here is my DYNO with a cut out.
or hell maybe turn downs off them towards the ground
