Fuel pressure.
Old May 1, 2007 | 10:11 PM
goodrich969's Avatar
Default Fuel pressure.
Im looking for the stock fuel pressure of a 96 LT1. I know they do 24 lbs/hr but what is the fuel pressure? Thanks
Old May 1, 2007 | 10:27 PM
SincalT/A's Avatar
i believe 43 psi.if thats not it i know im close.
Old May 1, 2007 | 10:34 PM
WhyHelloOfficer's Avatar
Should be between 41-43 psi at WOT I do believe.
Old May 1, 2007 | 11:03 PM
Ah thank you.
Old May 2, 2007 | 12:22 AM
96slow6's Avatar
Also 37 at idle.
Old May 2, 2007 | 09:34 AM
obe1 95Z28's Avatar
With the vacuum line removed from the FPR, the stock fuel pressure should be 41 - 47 psi.
Old May 2, 2007 | 11:03 AM
Smokinlt1's Avatar
^^^Mine was around 55psi when I dissconnected the vacuum line. At idle it's around 46-48psi. guess that explains the richness, what would you guys think it could be, tune? Fuel injectors don't leak, tested for that.
