cc304 vs. crane 2033 #s
If that's the only thing holding you back, may I recommend the Comp 503 cam.
The stock LT1 does very well with a wet shot of nitrous as it is. If that's all you wanna do then stay stock.
Less overlap ='s less wasted NOS.
If you want the sleeper then the cc304 would definitely be better. Unless you're spraying over 200 shot, the LSA doesn't really make much difference.
Like I said before, no matter what you should get a tune. www.PCMforless.com they can hook you up for much less than you're thinking. I'm not an auto guy so I don't know TCs.
