ABS Que stion...
Old May 3, 2007 | 08:55 PM
TheBiz's Avatar
Default ABS Que stion...
Looking to by the SJM ABS delete kit. How do I know if I have a 4 channel or a 3 channel ABS.
Old May 3, 2007 | 09:37 PM
indirocz28's Avatar
Its probably 3channel, but
Look to see how many brake lines go to the rear of the car from the ABS unit under the hood. there should be 2 going to each side of the front, then one to the rear, or two to the rear, just depends on the vehicle..
Old May 3, 2007 | 09:42 PM
the_merv's Avatar
I think all the LT1's are 3-channel.
Old May 3, 2007 | 10:36 PM
cody161's Avatar
i was told at the horse power house if u have traction control it is 4 channel if not then you have 3 channel
Old May 3, 2007 | 10:40 PM
the_merv's Avatar
I don't have TC, so you are probably right with that. Someone with TC chime in..
Old May 3, 2007 | 11:29 PM
95FbFormula's Avatar
LOL I asked this like a month ago if you have Trac control you have 4-channel if not then you have 3-channel. Also if you want if you have TC and delete the ABS you can delete the TC also.
