Timing Chain Help??
Timing Chain Help??
Just got around to installing my timing chain and need to know which mark to put it on? It's a Cloyes double roller part# CLO-9-3145. My rods are hitting the cam so I want to make sure its on right before I go grinding on the rods. My dumbass lost the instructions . If anyone has one let me know what mark is what. Thanks
BTW its a LT1 383
BTW its a LT1 383
ok if its the same as the gen I sbc then there should be a square that should make its advanced a triangle that should make it retarded <--i might have those mixed up and a circle witch is factory cam position
ok i just looked it up 4 degrees advanced is the triangle and 4 degrees retarded is the square and the circle is factory position
