headgasket questions
Old May 4, 2007 | 12:39 AM
Ironxcross's Avatar
Default headgasket questions
hypothetically, if my head gaskets blew out and i had to replace them, and i decided to go with the impala gaskets, would i need to retune since its bumping up the cr?
Old May 4, 2007 | 06:27 AM
Ironxcross's Avatar
anyone?
Old May 4, 2007 | 06:02 PM
Smokinlt1's Avatar
ttt I'd like to know.
Old May 4, 2007 | 06:09 PM
Ironxcross's Avatar
i know, i'd think get an answer by now. im curious because if it nets a few hp, a repair could turn into a possible modding opportunity
but i want to see if the tune would be off because... you know, those tuning things are goofy.
Old May 4, 2007 | 07:12 PM
the_merv's Avatar
Veteran: Air Force
Personally I would get one cause the LT1 is really touchy with that cause of the factory Cam.
Old May 4, 2007 | 08:48 PM
Ironxcross's Avatar
what kinda hp increase would you see with going to the impala headgaskets?
Old May 4, 2007 | 08:55 PM
fergymoto's Avatar
I put the Mr. Gasket .026" compressed height head gaskets on my LT1 truck and it has no issues. Factory tune.
Old May 4, 2007 | 09:16 PM
the_merv's Avatar
Veteran: Air Force
Maybe like 2..
Old May 5, 2007 | 05:32 AM
Ironxcross's Avatar
haha, alright
Old May 5, 2007 | 10:24 AM
mtaylor's Avatar
i know what your talkin about when it comes to a modding opputunity...ha i blew a head gasket and the car now has the motor pulled, heads getting port and polished, new cam,waterpump,plugs/wires, new opti, 1.6rr, springs, pretty much everythig new except the rotating assembly.
Old May 5, 2007 | 10:40 AM
Karl Ellwein's Avatar
If you went with the Victor Reinz .026" head gaskets it should (in theory) increase the motors resistance to detonation. The better quench is really more usefull than the higher static compression ratio. (they are both good to have so it's a win-win).
I don't think you would need a re-tune.
Old May 5, 2007 | 10:58 AM
plaf713's Avatar
wouldnt the pushrod length change?
Old May 5, 2007 | 11:39 AM
the_merv's Avatar
Veteran: Air Force
No cause the Rocker Ratio isn't high enough to mess up the angle to where it would offset the Valves.
