Can u add traction control to 97 z28?
Old May 4, 2007 | 07:37 AM
pat_r1ck's Avatar
Question Can u add traction control to 97 z28?
Wanted to know if anyone could answer this question for me, also if it was even worth the trouble & $ to install one...thanks - patrick
Old May 4, 2007 | 07:53 AM
Javier97Z28's Avatar
Uses 4 channel ABS so you need to make some changes in the rear or swap to a TCS equipped car rear end... plus all the other changes to add it in.
Don't see why anyone would want this...
Old May 4, 2007 | 08:46 AM
engineermike's Avatar
Everyone I know who has it turns it off imediately.
Old May 4, 2007 | 08:53 AM
LT1MAN's Avatar
just use your right foot to operate the traction control pedal located directly to the right of the brake pedal.
Old May 4, 2007 | 08:58 AM
roadhog_113's Avatar
don't bother traction control is useless!!!! Unless you are ripping around with people from an old folks home
Old May 4, 2007 | 10:00 AM
kyles2000z's Avatar
why would you want traction control. everyones always turns it off first thing when they crank their car up. just use skill and throttle control to avoid wheelspin, not a freakin device. it wouldnt be worth the swap IMO, if it can be done.
Old May 4, 2007 | 10:03 AM
ZFan88's Avatar
Plus it's an ugly box sitting above your driver-side head
Old May 4, 2007 | 10:39 AM
plaf713's Avatar
dont do it man, you really dont need it, and if you do it you'll always have it off save your money for some mods
Old May 4, 2007 | 12:06 PM
95FbFormula's Avatar
Ya its junk I always turned mine off now I am just getting ride of it. Along with the abs
Old May 4, 2007 | 12:32 PM
rasputin's Avatar
qft!!!
Old May 4, 2007 | 12:54 PM
97blkz's Avatar
You want it I'll rip my box out and sell it to you,
Old May 4, 2007 | 09:51 PM
siniSSter's Avatar
+? Trust us...you don't want traction control. Damn nasty looking box on the side of the valve cover, plus its damn embarassing when you forget to turn if off at the line. Come on guys...I know it just doesn't happen to me.
Old May 4, 2007 | 10:17 PM
F8L LT1 Z28's Avatar
