Random mis-fire code.
Old May 4, 2007 | 06:00 PM
Chico05RST's Avatar
Default Random mis-fire code.
I just got the bird put back together and now I'm still throwing a random mis-fire code. 1996 T/A
first I stripped the teath off the water pump gear and caused the timing chain to break.(but the car was at idial when it broke. It threw the p0300 code after the chain broke so I am asuming that was the cause of the code(t/c braking). So I then pulled the intake to get the water pump gear out and re sealed every thing bac up checked all of my conections and every thing is in tacked.
so now the car runs, good idal, good oil press, and fuel press. but the ses light flashes and it sounds like a demo derby car. And it bogs down when I accelerate it. Any help with trying to figure it out would be helpful.
Old May 4, 2007 | 10:47 PM
great421's Avatar
Your cam and crank are off (at least) one tooth - that's my bet...
(Sorry to be the bearer of bad news)
Old May 6, 2007 | 02:48 PM
Chico05RST's Avatar
Just checked the the cam and the crank gear and everything is lined up dot to dot. I just ordered a new opti and wire harness.
