Adjusting Comp Cam Pro Magnum Roller Rockers
The problem I am having is the set screw will not hold unless I tighten them down 3/4 to 1 full turn rather than the 1/2 at 0 slack. My compression numbers are dead accurate so the additional turn does not appear to effect anything??
By the way they did feel tight untill I check one with an open end wrench and was surprised it still moved after being tightened with the allen screw?? turned it 1/2 more and locked tight. What gives???
Did you have same problem???
Do the roller rockers stop the oil spray or splash when adjustring well running??
