Deleting oil cooler???
Old May 6, 2007 | 10:22 AM
matt94z's Avatar
Default Deleting oil cooler???
We dropped my new motor in last night, and decided to leave my old oil cooler off. What do I have to do with the radiator? Just buy another radiator hose? Thanks.
Old May 6, 2007 | 12:12 PM
95FbFormula's Avatar
Are you talking about the Cooler that is built onto the rad or the oil cooler that cam on some cars.?
Old May 6, 2007 | 02:18 PM
Formula350's Avatar
Remove the lines, and the adapter on the block, then you just go. If the radiator is new, it won't have any oil in it and you don't have to block anything off. Otherwise, you can just cap it off, or clean it out with one of those compressed can with cleaner in it.
Old May 6, 2007 | 02:35 PM
themadspoon's Avatar
You have to run the lines from the radiator like they would be on a car without a cooler. Oil doesnt flow to the radiator antifreeze flows to the filter housing.
Old May 6, 2007 | 08:12 PM
matt94z's Avatar
Thats what I was thinking. I'll look at a buddies car to see what kind of radiator hose is on his.
Old May 6, 2007 | 10:24 PM
Formula350's Avatar
Why on earth would they do that? Doesn't make any sense to me.
Old May 7, 2007 | 12:05 AM
GMRACER13's Avatar
When you delete the cooler you can use an oil filter from a '96 1500 2 wheel drive truck for more capacity.
Old May 7, 2007 | 12:25 AM
daniel6718's Avatar
all you have to do is run a hose from the waterpumnp to the radiator, as if the cooler was never there
Old May 7, 2007 | 02:31 AM
matt94z's Avatar
New motor has a 7 qt Miloden pan, I won't need more capacity
Old May 7, 2007 | 02:33 AM
matt94z's Avatar
Makes it easy enough, I'll need that and a vented opti and she's ready to fire up
Old May 7, 2007 | 04:57 AM
3pnt4maro's Avatar
x2 did that and mine runs fine
