LT1 Tuners inside
also which is more cost effective? i havent seen any prices for tunercat but ive seen LT1 edit is about $425 for one pcm i believe.
i was gonna wait and see if hptuners would make an obdII program but that doesnt seem like its gonna happen.
As to the options, converting to obd1 will probably be the cheapest (tunercat is around $90, plus the cost to convert ($250 or so). But also you really need a datalogging program to tune yourself. You can get datamaster for around $100 but the only good one I know of for lt1 obd2 is autotap enhanced which is around 300 I believe.
Depending on what the application is there can be some downsides to that approach though, like for example it is much easier to pass emissions with obd2.
I was in the same place you are and this was the best option.
And another thing, they can get you a MUCH better tune if they had a data log, so if youw ant it closer than just there best guess your going to need to get the cable anyway. so now its just the cost of the tuning so???are to load the bin file and about 15 mins of your time modifying a OBD1 pcm to work in your car.
