Catted y-pipe vs. ORY
Old May 9, 2007 | 09:32 AM
StealthFormula's Avatar
Originally Posted by Formula350
Bored and read this thread. I have to say that flanged Cat idea is brilliant lol That's at least as clever as cutting the casing off the cat and welding it around a straight pipe. Hell it might even be better haha
I'm thinking of an ORY since there's no emissions here. I don't have access to a welder though
the flanged cat gets them inspection bastards every year haha. Get someone to weld it cats are the devil!
Old May 9, 2007 | 09:33 AM
Originally Posted by Ironxcross
so i'd need:
headers, y-pipe, 2 24' o2 extentions, another cat (that matches the y-pipe diameter, and to get all the piping to match up.. right?
pretty much and of course a tune so you can get the rear 02's deleted.
Old May 9, 2007 | 10:30 AM
Formula350's Avatar
Yea, touching cats other than factory needs is a big no no :\ What you can do is just bring the cat to them with what you want done, then they aren't liable since it wasn't on a car. You can just tell them its an off-road application for more back pressure on your turbo. Who cares what you make up lol
I don't need cats though, but I still would have the problem of finding a place to weld in the ORY w/o me having a cat :\
Not to thread Hijack, but do the dual cat Y's bolt into a 93 w/o problems? I'm sure people here have their old setup and would sell for cheap, it'd still be an upgrade for me heh
Old May 9, 2007 | 01:05 PM
BizZzatch350's Avatar
Moderator
Flanging is a great idea until you start looking at what flanges cost. You potentialy would need 8 flanges if you did the dual cat set up. I used to think the FLP set up was over priced now looking at it, it's actually a good deal for all that you get. Far as question of motor mounts, its a good idea to change them because you will have no easier time to do so. I only paid 100$ for a used set of coated hooker LTs, not shiny coating but coated none the less. I also have about close to 400$ in the Y pipe with cats.
Old May 9, 2007 | 01:36 PM
Formula350's Avatar
6 flanges, not 8. 2 per insert pipe which is 2 versions of the insert, so 4 total there. Then 2 on each side of the exhaust, for a total of 6.
Old May 9, 2007 | 01:44 PM
If your running dual cats on a y-pipe then it would be 8 flanges, one of each side of the cat s theres 4 b/c 2 cats then one on each side of the piping on the y-pipe where it connects theres 8. But if u just run a single cat after the Y thats 4 flanges
