LT1 engine removal
Did it last week..
Disconnect A/C lines only, do not need to remove the pump. I didnt even disconnect them from the pump, just at the other end of the 2 lines.
PS, just unbolt the resevoir from the shock tower and lay on top of the motor.
Dont forget that there's a ground strap from the head/coil to the drivers frame rail.
Also need to unbolt steering shaft from the rack.
Disconnect the coolant hoses, unbolt shocks from tower and remove y-pipe, support k-member and transmission with jacks, unbolt k-member and trans cross-member, lift car away.
itll be like hanging the engine by its *****
word for the wise! buy a LT1 hook it has 4 bolts that go where your fuel rail bolts go and pulls right of the top with a swivel like thing... its awesome!!!
http://www.automedia.com/Camaro/Cher...ht20020701ch/2
