engine noise
Old May 15, 2007 | 07:58 AM
topgunbar0's Avatar
Default engine noise
started about a week ago, i used to hear a ton of noise coming from the exhaust, now when i drive it i hear a TON of noise coming from the engine, and can hardly hear my exhaust at all, any ideas? thanks
Old May 15, 2007 | 08:31 AM
Formula350's Avatar
Can you record the noise for us at all? Could be a blown lifter or a valve problem if you hear it through the exhaust.
Old May 15, 2007 | 08:44 AM
topgunbar0's Avatar
its kind of hard to hear on just a recording, but you cant hear it form the exhaust or idling at all, maily when you get into it, all you can hear is the motor running really hard, and LOUD, and hear virtually every piston firing
Old May 15, 2007 | 08:52 AM
Formula350's Avatar
My advice would be park it and don't even start it till you figure this out.
Old May 15, 2007 | 09:04 AM
topgunbar0's Avatar
maybe i should, but then again, i dont have anything else to drive....and my buddy that has and IROC, a 94, and a 99 sais its fine, but it just doesnt seem so to me
Old May 15, 2007 | 09:07 AM
Formula350's Avatar
It very well could be, but man loud noises usually aren't good, especially if you hear it out the exhaust. Now, metal carries sound, so something could be lose, like your exhaust connecting to the manifold broke or something. Just baby it. Check the oil, smell it for gas or coolant. Check the transmission, smell it to see if it's burnt (you'll know, stinks real lovely). Make sure everything is plugged in under the hood. Look under the car while it's rattling. If you have a long screwdriver or prybar you can put it up against the parts of the motor (Valve cover, head, block, etc) and grip the end with your hand, and put your ear to your fist. If the clacking is louder say, on the head than on the block it could be head problems.
Old May 15, 2007 | 09:24 AM
topgunbar0's Avatar
ya the heads were my first thought, and it very possibly could be, but im doing a new exhaust and tune up here in a couple weeks, so hopefully i will figure it out in the process of tuning it up
