swap engine..
Old May 15, 2007 | 11:28 PM
woojong's Avatar
Default swap engine..
i swaped 96 corvette engine to trans am ws6.
but i am not sure if ws6 ECU can working with corvette engine...
will it be working with just 96ws6 ECU for 96 corvette engine?
or do i have to tune the 96ws6 ECU?
what should i do?
Old May 15, 2007 | 11:50 PM
the_merv's Avatar
Veteran: Air Force
Same Engine, LT1 is a LT1 between the Corvettes and the F-bodies. Even the same Cam.
As long as they both are a 1996, you are good. Just put on the F-body Acessories, and make sure all Connectors are in the right spot.
When you want to drop a LS Engine in there, hit me up also..
Old May 16, 2007 | 01:27 AM
woojong's Avatar
i swaped also transmission... will it be same? both of cars are auto..
so i put corvette engine with transmission...
how about speedo? i think it might be change a little bit...or not...
hehet~ thanks.. murb~
im a member of f-body club in korea..
so sometimes we swap ls-1 to v6car.. if i have a chance to get ls1..
i will ask you first..
thanks..
Old May 16, 2007 | 01:38 AM
the_merv's Avatar
Veteran: Air Force
Everything is the same, just make sure you use your Acessories, and you are good. Use the Corvette Convertor if you have it, it's a 2000 Stall.
You are doing all that in Korea.. that's prett coool. It must be expensive, from what I hear, Chevy V8's go for some goood money...
