LT's and 1" Drop?
Old May 17, 2007 | 11:58 AM
LT1_King's Avatar
Default LT's and 1" Drop?
hey guys i have a 94Z A4. i was wondering if i were to put a lowering kit that advertises at 1" if some LT's would work with ORY?
Old May 17, 2007 | 12:39 PM
lt197formula's Avatar
I would think so but it is only leave you with around 1-2 inches of clearance. What kind of long tubes are you going to get?
Old May 17, 2007 | 12:59 PM
LT1_King's Avatar
i'm gonna get some Pacesetters LT's with ORY. i already have the LM1. do you think i would scrape just driving around?
Old May 17, 2007 | 01:01 PM
BizZzatch350's Avatar
Moderator
Lot of it depends on the Y, from the collector to the ground, I could see doing an inch drop. If you got the Y to tuck up really good, I say its doable. Buddies 30th was dropped with Hookers LT, would never want to daily drive it, car looked awesome though. I could never drop mine, theres only 3 or so inches of clearance for the driver side cat.
Old May 17, 2007 | 01:04 PM
LT1_King's Avatar
i want the Pro-Kit from Eibach. but if it's going to scrape i will probly just leave it alone. i'll do the LT's first and see if it will clear first. then i'll think about the Pro-Kit.
Old May 17, 2007 | 01:07 PM
Moderator
Prokit wont be to bad, sportlines would not work
Old May 17, 2007 | 01:15 PM
gallardo259's Avatar
Do some lt's hang lower than others? or is it the y that is the lowest point? like will kooks lt's and y with the pro-kit be worse than any other lt's and y?
Old May 17, 2007 | 01:38 PM
LT1_King's Avatar
are hookers with the mufflex ory the lowest clearence LT's? a friend of mine said the Pacesetters tucked up pretty good.
Old May 17, 2007 | 02:28 PM
LT1MAN's Avatar
what you need to drop......................
.................is that cat
Old May 17, 2007 | 03:21 PM
LT1Z/28's Avatar
pacesetter's and prokit work well, thats what i have and i never drag them or the y pipe
Old May 17, 2007 | 03:48 PM
C_Rules's Avatar
go with the AS&M mids they have 1/34 primaries but the collector isn't 3 inches. however the y pipe collector is 3 inches so you can run a 3inch cat back. I have them and really enjoy them plenty of ground clearance.
Old May 17, 2007 | 04:17 PM
Gun5's Avatar
i got hooker LT's and a 1.5 drop from BMR.. im more likely to rub my exhaust tips backing off of hills, but i know how to drive over speed bumps and such rarely hit if i do its the damn flange
Old May 17, 2007 | 04:23 PM
SSweet97's Avatar
I've got Hooker LT's and BMR lowering springs 1" drop for three years now without any problems, you definitely have to go slow over these giant speed bumps that every retail parking lot has.
Old May 17, 2007 | 05:22 PM
Lt1junkie's Avatar
I got hooker lt's and the whole hooker catback & ory, I lowered mine 1.8 in the front 1.5 in the rear and i sometimes bottom out but not that often just careful where i drive. defentily can;t get threw a apartment complex or anything like that cause my car gets stuck cause the speed bumps.. But the things we sacrafice for looks
Old May 17, 2007 | 06:31 PM
camar0corey's Avatar
I was looking at the BMR springs, do they drop only the 1" they are advertised to do? I will have longtubes here shortly, so I am curious now.
What are you running for wheels and tires SSsweet97? Have a picture of the car with the springs installed?
Old May 28, 2007 | 01:03 PM
Gun5's Avatar
the BMR's take away the fender gap and are great as ride quality goes still
Old May 28, 2007 | 02:15 PM
the_merv's Avatar
I have the Pace Setters and Eibach Pro Kit, it scraped maybe once or twice when it was in there.. not to bad.
Old May 28, 2007 | 04:30 PM
Captainofiron's Avatar
talk to Sam Strano about lowering your car, he has the best stuff
Old May 28, 2007 | 11:08 PM
93BlackZ28's Avatar
Its been done, the only problem i have is pulling in my drive way but its pretty steep. I have pacesetter LTs and hotchkis 1" drop.
Old Jun 3, 2007 | 10:48 PM
93blcZ28's Avatar
ive had no problems, i expected way more, pacesetter lt's and id say at least 1.5'' drop with my prokit
