93 TA Engine Build Advise
Old May 21, 2007 | 07:12 AM
nhodge93's Avatar
Default 93 TA Engine Build Advise
Hey guys, what's up?? I am in the process of looking for a LT1 block to start a 355 or a 383 build. I have a few questions for those of you who have done this already. I will list the questions since there are alot..lol.
#1) Does it matter what year block I get, since mine is a 93 w/ speed density or can I just convert any year LT1 block?? I just bought a MSD Opti Spark thats why I'm asking, rather not waste a $540 opti spark if I don't have to.
#2) What would you suggest for a good street engine, probably not going to see the track much. A 355 or 383?? I'm going to spray it too, probably a 125 shot. Also as far as rotating assembly, what should I get? Can I use cast steel crank or should I go with all forged internals??
#3) Have any of you guys got your 383 engines to pass emmisions but still put out decent power?? I know having to pass emmisions limits you on your cam choice but just thought I'd ask.
#4) Should I use my stock intake and heads or LT4 heads, have them ported by Llyod or should I get the new Edelbrock intake and some aftermarket heads and have them ported??
Sorry for all the questions, I just want to do this thing right, if I'm going to do it. I thought since most of you guys have already been through this, that you could probably answer all these questions. If some of these questions have already been asked, I apologize, I searched but nothing came up that answered my questions, unless I overlooked it. Anyways, any help would be greatly appreciated.
-Nick-
Old May 21, 2007 | 01:32 PM
nhodge93's Avatar
Anybody????
Old May 21, 2007 | 01:56 PM
Speed Density's Avatar
hashtagBMW
Block choice is really nothing to worrry about, unless you have your hands on a vette block then your going to be using an Iron 2- Bolt block. As for optisparks, your 93' is a vented opti. Same with the 94's. 95-97 used non-vented optisparks.
Most guys stick with OEM opti's anyway, they seem to hold up just as well as aftermarket in some casses and are much cheaper.
Biggest thing anyone is going to say is..."What is your Budget?" thats pretty much the deciding factor in most builds nowadays. If you have the money the yes, go with the longer stroke 383. But if your limited on funds get your stock crank balanced and polished and throw a 6in Rod/Piston combo in there and it will scream.
Lots of guys make great power and can still pass SMOG, its not much in the size of the engine, but more in the camshaft selection. Just get ahold of some good reputable shops and they can surely help you select a smog legal cam that makes power.
For your goals I would stick with Ported stock castings (heads/intake) for the setup, your not going to need to up it to say an AFR casting etc..
As far as the edelbrock stuff goes, its pretty much been proven to be junk on the cylinder head side. And the new intake has yet to really 'prove' anything.
And if you have any 93' specific questions, just run over to www.speeddensity.org its a site just for the 93' LT1's
Hope this helps.
Tony.
Old May 21, 2007 | 03:29 PM
lt1taracing's Avatar
i run a 93 with the factory computer (with a chip burned). blocks are the same. 93-94 are non vented while 95-97 are vented. when replacing the cam with an aftermarket, you'll need to shorten the "pin" on the front of the cam. no big deal (dremmel tool). i run a cast crank from scat and havent had a problem with it. although i originally bought one from CAT(cal auto transpeed) and it cracked after about 6 months. the CAT brand cranks are junk.IMO. i have stock heads that are ported(with stock valves). they flow around .250@ .600. the edlebrocks are copies of the lt4 heads and flow around .230@.600. i also run a 200 shot of n2o. i did go with forged rods (5.7) and forged pistons. you'll gain around 1 point of compression when stroking the engine to a 383 if you use the same type of pistons (flat tops). but should still run fine on pumpgas (93 octane).
