Need advice on 2 bolt or 4 bolt main...
Old May 22, 2007 | 10:54 AM
nhodge93's Avatar
Default Need advice on 2 bolt or 4 bolt main...
Will a 2 bolt main be good enough for a 383 LTI w/ 400ish rear wheel horsepower? Possibly going to spray it w/ 125 or 150 shot. Or should I go with 4 bolt main??
-Nick-
Old May 22, 2007 | 11:21 AM
the_merv's Avatar
Veteran: Air Force
It you have the chance to get a 4-bolt, grab it. You can always splay the 2-bolt also.
Old May 22, 2007 | 11:27 AM
nhodge93's Avatar
I found a guy wanting to sell a vette 4 bolt main block for $700.00, is this a fair price?? I was thinking of offering him $500.00, what do you think??
Old May 22, 2007 | 12:44 PM
1989GTA's Avatar
I bought a nice used 1999 Vortec 4 bolt block for $200.
Old May 22, 2007 | 01:30 PM
BlackScreaminMachine's Avatar
Internet Mechanic
I had mine splayed, looks hella sweet!
Old May 22, 2007 | 01:40 PM
nhodge93's Avatar
So should I just get a 2-bolt block and have it splayed??
Old May 22, 2007 | 02:12 PM
lt197formula's Avatar
To my knowledge a splayed 2-bolt block is stronger than a stock 4-bolt block. So yes I would just buy it and have it splayed.
Old May 22, 2007 | 03:25 PM
F8L LT1 Z28's Avatar
That is what I was going to say
Old May 22, 2007 | 03:30 PM
No, just get the 2-bolt block and do the 4-bolt splayed.
I just got a 496 4 bolt main block for $750
Old May 22, 2007 | 03:34 PM
Imnotfast's Avatar
2bolt will handle what your looking to do. Put ARP studs and call it good.
Old May 22, 2007 | 04:44 PM
True it will but the question is for how long... If you have the money you might as well have the block splayed now.
Old May 22, 2007 | 04:48 PM
94strokedz's Avatar
I wouldnt run a 2 bolt in your case. My 383 was only 350ish to the ground(mustang dyno, so near 400), plus a 150 shot(450 something on the juice if I remember right), for one summer, maybe 10 or so bottles total, and my main bearings were very near spun. The caps were walking on the block as well. I would splay a 2bolt if I were you. It will only cost you a few hundred bucks in machining, so why not. Right now you plan on only 400 rwhp plus a small shot, but what happens when you get bored next year and would like a lot more power, then you're going to be redoing the bottom end anyways.
Old May 23, 2007 | 02:35 PM
Imnotfast's Avatar
One of the guys is running a 2 bolt/arp studs with a 175 shot for the last 6 years. last june went thru his engine..and everything looked great.
Yes if you have the extra money to do a splayed bolt conversion then do it right and get them pinned. The pinning is a bigger help then the 4-bolt. Just very hard to pin a 2bolt.
Old May 23, 2007 | 02:59 PM
383LT1S10's Avatar
Like already stated. A splayed 2 bolt is superior to a 4 bolt.
