Trans am vs. ?????
Old May 23, 2007 | 05:35 PM
TravisMcGill2000's Avatar
Default Trans am vs. ?????
hey guys my buddies got a 2004 ???? he is running 17 or 19lbs of boost and putting down 253 whp and 290wtq on a dynameter. he is wanting to run me from a 40 kick because he said his car spins to much. wat kind of race is this going to be for me. I know i kind out run him from a dig but i dont no about a roll. wat do yall guys think. i have a 94 TA a4 LT's,4in y,flowmasters, CAI, foil,pulleys,smaller balancer,3.73,free mods, plus just added rebuilt tranny, 3000stall, shift kit, amd the car now ways 3380
Old May 23, 2007 | 05:37 PM
its a neon ?????
Old May 23, 2007 | 05:54 PM
SincalT/A's Avatar
i have a friend that used to own a neon running similar numbers.i think he would trap about 105-106 mph in the 1/4.
Old May 23, 2007 | 05:56 PM
The LT1 That Could's Avatar
if you don't beat him....kick yourself in the junk! 2nd gear from a 40 roll should have you well in your powerband.
Old May 23, 2007 | 06:09 PM
Formula350's Avatar
Everyone here says the ????s are slow, I think they aren't and hate me all you want, but my money is on him.
My car pulls much better @ 30 because it kicks down to first. If yours is the same, tell him you'll do it from 30
Old May 23, 2007 | 06:36 PM
at 30 mine will not kick down to 1 i wish it wold though, i am going to tell i will run him from a 40 roll if he runs me from a 20 roll which puts me a 4500 rpm in 1st. 40 roll is 3300 rpm in 2nd. the guy in the neon beat my buddies 98 z28 which is stock by a 1 1/2 cars
Old May 23, 2007 | 06:48 PM
Formula350's Avatar
Hmm, I even assumed you had an A4. Seeing as we don't know anything about your car, what specs is it, and what gears are you running?
Old May 23, 2007 | 06:51 PM
all my bolt-ons r on the end of the post
Old May 23, 2007 | 07:50 PM
screw letting the tranny kick down....manually downshift that fugger into the gear you want. Don't tell you're doing roll racing in OD!?!?!
you should be even with or a bit faster than a stock LS1 with your mods.
Run him from 40 in 2nd gear, nail it, shift into D as to not have the car bang the limiter and put some lengths on him. You're car is prolly making in the 290s rw, and weight doesn't matter from a roll...mass in motion.
Old May 23, 2007 | 07:59 PM
burnzilla's Avatar
3.73's a 3000 stall and Longtubes?.?.?
I don't know anything about the skittles but you should be a high 12 with good hook.
Tell him if youre going to agree to race from a roll, you also want a dig race. Thats fair.
Old May 23, 2007 | 08:06 PM
yea that sounds fair to me too, and i mean that in first it would be like 5800rpms at 30 in 1st. my car ran 8.42 before weight reduction and 3000 stall and shift kit so i think i should get a stock ls1 by a 2 or three cars easy but i dont know
Old May 23, 2007 | 08:07 PM
i will let yall know in a few days the results
Old May 23, 2007 | 08:17 PM
Formula350's Avatar
Ah, I didn't read the first post that far LOL I just saw specs and passed it off for some reason. I'm retarded, I know
I think you should take him, but it might be a good race. He is right, those ????s don't get traction.
Old May 23, 2007 | 08:55 PM
Get you some stickies tho. 3.73s and a stall aren't a street tire friendly combo!
Don't forget the stall doesn't only help you launch the car at a higher rpm, it will also give you a better shift extension...keep the RPMs up a little higher after shift.
You should hand this guy his skittle-ly *** with ease!
Old May 23, 2007 | 09:24 PM
That_guy's Avatar
Youve been slipping lately lol r u sick. But to the op i think you can take him you said he raced ur friend in his stock camaro and he beat him by 1 1/2 cars, well since u have those mods i dnt see no reason for you to lose but go ahead and do what i do lol use the transmission perform button.
Old May 23, 2007 | 09:46 PM
how will the stall work from a roll, will it pull harder and yall think i can run mid 12's with DR's
Old May 23, 2007 | 09:57 PM
Z ROADSTER's Avatar
They forgot to tell you the neon is on the bottle but he only uses it for real close races & he can't hit the juice down low like from a dig thats way he wants to PUNCH from 30 MPH !
Old May 23, 2007 | 10:00 PM
connexion2005's Avatar
My ls1 cut a 8.4 with my mods in sig. I don't see ur buddies ls1 being stock running a 8.4 although it is possible with sticky tires. Either way I think you will pull on him but if the race gets into the 100's he will pull back even and begin to leave.
Old May 23, 2007 | 10:01 PM
he does not have the bottle i haved looked his car over very well, plus if he did he would blow to hell and back with all the boost he's running on a stock motor
Old May 23, 2007 | 10:05 PM
no i ran 8.42 before 3000 stall, shift kit,and weight reduction, his car run 8.8's stock a4. i dont know about the 100 mph thing i should have the same hp as he does
