Need Help with DTC codes!!!
Old May 24, 2007 | 10:58 AM
94_lt1_4mula's Avatar
Default Need Help with DTC codes!!!
i have a 1994 pontiac firebird formula its a 6spd and i am pulling codes 84 85 and 15. if any body can tell me what those codes are
Thank you in advance
Old May 24, 2007 | 11:10 AM
FAD2BLK93's Avatar
CODE 15 engine coolant sensor signal voltage low or low temp
code 84 3-2 control solenoid
code 85 trans TCC solenoid stuck on
For all the DTC codes go to www.shbox.com go to the tech page then go to the manuals and spec page.
Old May 24, 2007 | 02:10 PM
well since i have a manual transmission it would be skip shift solenoid circuit??? meaning and trans tcc solenoid stuck on??? meaning
can i replace these solenoids if so please tell me where
thank you
