L98 Performance Help
Formula350... Is this the Ramjet EFI kit you mentioned? Where did you find it for $1300? http://store.summitracing.com/partde...5&autoview=sku
i dont know why nobody has suggested this, but, sell your heads. freshen up the bottom end and get a good set of vortec heads from GMPP. match that with a good intake within the range a the cam you choose. use a good hydrualic roller around 220* @.050 or so. top it all off with any carb of your choice. thats about the easiest, cheapest 400hp out there today. i believe CarCraft did a little Vortec headed build a few months back. i'd have to look again. either way, you can do this for around $1200, if you dont need alot a machine work and dont have to replace things like your crank or rods. not to mention, whatever money you get for the heads. just a thought.
The vortec head option is also a good way to go. Those heads I think can make more torque than the L98.
250.00 lt1 heads
100.00 intake w/tb and injectors
200.00 having intake adapted for reg distributor
100.00 having heads adapted for gen1 block
0.00 cam from me makes you a stock lt1 with 275HP
650.00+/- makes you an LT1 pretty much and you can usually get 300-400 for the L98 aluminums.
or...
do the above but sell the L98s and get the heads ported then throw in a cc306 or gm847 for 250.00, 918 springs for 150.00, pushrods for 90.00, etc.
ALL... Will "any" Gen1 heads/intake fit the L98? If so, maybe I'll swap some parts from the ol' SBC and just buy a new cam. Heads are port-matched Edlebrock Performer RPM and a dual quad Edelbrock RPM Air Gap intake/carbs. Do the heads require special springs for a roller cam? Will the shorty block-hugger headers swap over?
i would always replace springs to a stiffer aftermarket spring,most cars pick up a few tenths just by doing this....either the bee-hive spring or have the head machined buy the spring seats for alum.heads and put the 987 comp spring in there you will be happy in the end.
as far as the headers i do not really care for the regular block huggers however SANDERSON makes a set that work really well.
Regarding headers... I have very limited choice if I use the Jags That Run brand of engine swap kit. It sets the block back against the firewall and there are clearance issues with steering and other parts when other headers are used. I could keep the Hooker brand swap mounts but this moves the engine about 4 inches forward, which necessitates the use of pusher style electric fans when used with an electric water pump... but this kit allows use of long-tube headers. MSA makes a swap kit that places the engine about in the middle of the other two. I can't remember the brand but there is a set of semi-long-tube headers that work with the latter kit. I'm rambling... sorry.
BTW, I do NOT need to worry about passing emissions. The car is a 1974 and I'm in Texas
Grow up, will ya? There is plenty you can do to the TPI setup that lets it rev higher and keep making power. Unless you're going to give him a great deal on a L98 ready LT1 intake with the distributor boss, then leave him be. I've ran TPI and LT1 and I love them both.
I'm still saying he should pick up the set of Patriot Performance heads off either the Patriot Performance website or off ebay if he can, buy a used Lt1 intake and have it converted, and then have a custom cam ground (thunderracing.com has a special deal going on with a member here for a great price on cams and I can find his name if you want) and then run a either a stock harness and ecu from a TPI thirdgen OR run a Megasquirt (I can provide more information if you want) ecu which is a very badass setup that I will be switching to on my LT1 later this year. After he gets all the prom burning crap and a laptop, that will come out near the price of the Megasquirt. The tuning software for Megasquirt is free to download and is open source so new features are constantly being added.
LSXNV... Okay, so I can swap the Edelbrock heads onto the L98 and relegate the ol' sbc to wearing the L98's... probably should put a low-rev torquey cam and low-rise intake on the SBC to match things up. BTW, the older motor will be transplanted into another 260Z project. I already have a Crane digital ignition, coil, and a window switch for nitrous so I might as well put it on the L98. By freshen up the bottom end... you mean just new bearings, bolts, and rings, right?
1bdbrd... The ol' gears in my brain are still grinding... I've slowed my decision-making down a bit. No more rash decisions this year... err, week... or so. Yes, I would like the name of the member with the cam deal. If I decide to go EFI, I think the Megasquirt is my best option... might as well, I guess. Besides, I don't own a laptop... or a blackberry... or even a cell phone. See... I really am a cheap old bastage.
i like to over build the bottom end for my intended HP numbers. because nitrous is sooo easy to just bolt on and go. that, and i have been known to "over-rev" an engine in the burnout box.
http://www.gmpartsdirect.com search for 12498032. They don't have the ECM, just the harness.
I still say run a modified LT1 intake. If you can run a LT1 intake on a TPI harness and ECM, then you're golden. If you want, Painless sells the TPI harness for $300, ready to go.
I don't want to just kill Mustangs... wanna PULVERIZE 'em!!!!
Personally, if I had the $$, I'd get a LT1 intake and heads machined for the GenI block and then run that. If you want to run a carb intake, I'd run something like this
Part# 10051102
I'm sure Edel or Holley makes one similar for less than $300, but who knows. I suppose it's really not all that bad of a price. Run a nice Demon 650cfm
It'd def look aggressive as hell! With the weight of you car, you don't need as much as you're thinking. 400hp for you is like 550hp for us. You've got 1/2 a ton less weight on us. And a mustang weights about the same as a FBody, so you don't need to worry about smoking one, even with a stock TPI or LT1 motor. Heck, I never lost to a Mustang in my TPI Firebird.
The intake you suggest looks an aweful lot like an Edel. Super Victor, which is good from 3500-8000 RPM. I'd need a 4K RPM stall converter for that, wouldn't I? I'd need one heck of a cam too. I don't think this motor will last long above 7K RPM. It would be a SCREAMER for sure but I'm looking for a combo that's good for a daily driver.
The car has a ~350 FWHP SBC in it now and it's okay... but it's far from enough. Id be very please with 700 FWHP... 500 WHP... more is even better, heh, heh. It's a matter of what I can afford.
When I started this thread I would have been happy with 400 WHP... but I'm getting greedy... mwah-ha-ha-ha-ha... [wringing hands with an evil grin].
