how do i remove this
Old May 28, 2007 | 06:17 PM
jester1614's Avatar
Default how do i remove this
I am trying to remove the crossover pipe at the rear of my fuel rail.
how do i get it out or is it removable.
Old May 28, 2007 | 06:21 PM
the_merv's Avatar
Are you trying to dis-assemble the Fuel Rails?
Old May 28, 2007 | 08:10 PM
jester1614's Avatar
correct if it is possible I am going to get the rails powder coated
Old May 28, 2007 | 08:15 PM
Formula350's Avatar
Get the line powder coated too then? Saves seeing part of it's ugly head when enough light permits.
I think it's just pressed in.
Old May 28, 2007 | 08:30 PM
the_merv's Avatar
It's a bitch to get out, mine didn't want to come apart as well, so I left it alone.
Old May 28, 2007 | 08:37 PM
jester1614's Avatar
i guess that i will get both crossover tubes coated then so they are all the same color
Old May 28, 2007 | 11:44 PM
Captainofiron's Avatar
I think all of it the same color would look good
Old May 29, 2007 | 02:03 AM
daniel6718's Avatar
what color fot eh rails? get them lines black...
Old May 29, 2007 | 01:44 PM
Fire67's Avatar
If you put the rails into a 400* oven to cure the powder coat, all the fittings will leak. Not pressed, swaged, but with a rubber o-ring to seal them. The rubber will be shot if subjected to those kinds of temps.
The caps at the front end, and the rear fittings all have an o-ring seal. If you look at the area where the fittings join to the rails, you see a angled ring around the steel part. That angled part of the aluminum is what holds the fittings in. You have to cut it off to remove the fittings. Making the removal permanent.
I removed mine because I was having AN fittings welded on for a custom fuel system. When I realized there was rubber seals in there, I went ahead and removed the front fittings and had plugs welded in.
Moral of the story, powder coating temps will make those seals leak, and will ruin your rails.
