MSD Opti vs. GM opti
+1 for Jegs giving me my 500 bucks back.
--Alan
installing it the way you did causes the opti disc cover to not sit properly causing a clearance issue with the rotor.
MSD offers a gasket instead of the O-ring you just have to ask for it.
GM.
I have the distributor back now, repaired. The car has run strong for around 2000 miles. No problems yet. The original GM opti has 95,000 miles on it. It still works, but needs a new rotor and cap. I changed the whole unit to MSD to avoid the hassle of changing it again. I got more than I bargained for.
why isnt this gasket or O-ring installed in the first place?
Also, when the Unit is shipped to me, I should open it up and put locktite on all the screws?
Also I dont know why they didnt install it.
The unit is shipped not ready to go, you need to open it and install the o-ring, but I wouldnt locktight them, the cap is plastic and will not expand and contract therefore the screws will probably not loosen up. As for the vibration thats another thing
